Home > Technical (L322) > Suspension question
kineavy
Suspension question
I have noticed the o/s/r suspension is slightly lower then the rest of the car. About an inch lower in all settings. It rises and falls as it should.
Is this something that I should be worried about? It had a new compressor fitted by a main dealer a few years ago.
After a quick search on here it may be an airbag leak?
Post #380202 31st Mar 2016 6:01pm
Probably just needs re-calibrating. There is a @ 10mm tolerance setting on suspension heights as well.
Nothing to be unduly worried about, my heights on all four corners vary depending on which way the wind is blowing on a day with a y in it Thumbs Up .
Post #380206 31st Mar 2016 6:34pm
