Home > Technical (L322) > GEARBOX D'OH!!!!!!!!!!!!! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Well the ffrr isn't giving me many reasons to keep it in fact it's rapidly climbing to the top of the endangered species list
28th Feb 2016 4:40pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34962 |
sorry to hear this Paul ,but i'm sure with your talents you'll figure this out.. ... - .- -.
28th Feb 2016 6:02pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7949 |
Can't think of much to check... how about the electrical plug to the box... you can "sort of" get it in place but in fact it's not... give it a pull and check it locked home OK...
28th Feb 2016 10:34pm |
At the moment I'm a bit stumped as to the cause, thought that it was a leak. The only solution that I can think of involves a gallon of petrol and a light The only bit that's changed is the torque converter, so that is obviously top of the list, but that wouldn't explain the straight to 5th Yesterday I couldn't spell Engineer... Today I are one!
Will give the plug a prod But it was ok for 30 odd miles before it all went tits up, which is why I thought that is was oil related.... Got a bad feeling that it's going to end up at a tranny specialist, which will result in a rebuild whether it needs it or not Yesterday I couldn't spell Engineer... Today I are one!
28th Feb 2016 10:42pm |
Hi Ed, the level's all correct, and it is new oil, the box was powerflushed on the Monday and the torque converter was changed the next evening, the car covered 4 miles max in between the oil change and the converter change. The transmission cooler is less than 17 months old, and was genuine, so I very much doubt that is at fault. And there is no way that the cooler is blocked as the power flush was done at the cooler return to the box, so all the oil has gone through it.
29th Feb 2016 12:06am |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Thanks for the clarifications.
29th Feb 2016 12:32am |
I can sort of see where you are coming from, I don't think that the powerflush did any harm as it was all OK after...And when I say powerflush I don't mean that it was plumbed in to a circulation pump, rather the return line from the cooler was disconnected and diverted to a can, new oil was added to the sump and then 2 lt's were run off with the engine running in gear, and then it was stopped and more was added until it ran clean. It was never run dry at any point of the flush.
29th Feb 2016 1:01am |
Right so the plot thickens...........
29th Feb 2016 1:42pm |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Hi Miggit,
29th Feb 2016 2:21pm |
Hi Steve,
29th Feb 2016 3:56pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7813 |
Sounds like the cost of the fuel would more than make up for the mechanical issues you're having
29th Feb 2016 4:06pm |
Well I'm now totally confused
29th Feb 2016 5:35pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Thinking aloud, could it be possible that the valve block is causing the TCC to be in a permanent state of partial lock, and it's become apparent with the new TC, whereas the old one had simply worn out as a result of a poor recon on the valve block that's now continued to get worse? It would fit but I don't know the valve block enough to be able to say if it's possible or not. Visiting from DISCO3.CO.UK
29th Feb 2016 5:49pm |
