Home > Technical (L322) > Small problems
roscomc
Small problems
Hi all, just bought a 2007 TDV8 SE about a month ago. The range rover is perfect and i love it, but there is 2 very small issues annoying me.
1. The bottom part of the boot , seems to have a mind of its own, when i open the top part its a guessing game to weather when you press the button for the bottom bit to open if it will or not. sometimes it works 10 times in a row, then sometimes not for ages.
2. The reverse camera, you can see when you go into reverse the camera goes on but its just black , you can see it flickering a bit so its obv working but no clear view. It was working up until 6 months ago the owner told me.
Just to let everyone know , even though I own a 1999 defender , I'm a total rookie with range rover. And a total rookie in general with mechanics, so go easy and idiot proof solutions lol
Thanks in advance.
Post #381770 11th Apr 2016 5:34pm
mjdronfield
Welcome....
Now brace yourself for calling it a Jeep....
Does the motor come on when you press to release the lower tailgate, or does nothing happen? Ie, is it the latches or the button?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #381788 11th Apr 2016 7:29pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I read 'the jeep' and then checked the flag..........it wasn't stars and stripes. Laughing
Post #381793 11th Apr 2016 7:44pm
roscomc
Sorry lads , I'll edit the post lol. When it does work the you can hear it when u press the button. But it hardly every does, the latches seem fine as there well greased up. Seems to be the button
Post #381794 11th Apr 2016 7:49pm
Duracell777
'Sounds like the actuator is in need of replacement. Had same symptoms with my D3. £45 and 20mins work and all was well again. Not sure how much actuator will cost for RR but someone may have one lurking in a box somewhere or you could try Dan at Duckworths. Thumbs Up
Good luck and welcome.
Post #381800 11th Apr 2016 8:39pm
PaulB
Welcome Very Happy Thumbs Up
Post #381803 11th Apr 2016 8:46pm
miggit
More likely to be a dodgy switch, they are not exactly in the best place to ensure that water doesn't sit on/in them.... and we know how good the L/R seals are Whistle
Firstly I reckon I'd be popping off the plastic trim cover that hides the switch, and just try it directly, with out the rubber cover... it might have gone hard... and they are less than a fiver to change Shocked You read it right Shocked If I'd have typed £5 you have thought that I'd missed the 0's off and reckon on 50-500 Rolling with laughter Rolling with laughter
From what I remember the switches aren't that frightening to buy... £40 springs to mind... but I'm probably thinking of a wiper blade Rolling with laughter Rolling with laughter Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #381819 11th Apr 2016 10:39pm
Stephen.125
2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Another thing it may be worth trying is to check the lock mechanisms are clean and lubed up, you can try WD40 initially but if it works use something more permanent. Another way to check if it's a mechanical 'friction' issue is to push on the lower tailgate (towards the front of the car) a little and then press the button. Mine was doing similar and some white lithium grease sorted it for the remaining 3 years I had the car.
The reverse camera is probably faulty- Think up until 2009 they have a seam around the casing, I replaced mine with a 2010 one to get the yellow lines (needs a new holder and moving slightly) IIRC user 'JustinP' took his apart and dried it, cleaned the board with contact cleaner spray and re-sealed.
Best of luck!
Steve Thumbs Up Formerly happymadison1978
Post #381839 12th Apr 2016 8:51am
miggit
FYI, I'm sure that I've seen a thread on here about replacing the camera with a cheapy one from fleabay..... hopefully someone can shed some light on this Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #381844 12th Apr 2016 9:38am
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hi
I had a blank screen on mine - Try the fuse (rear one in the boot) It's a 5 amp, I think postion 12 - I just removed all the 5 amp ones till I found one that had blown.
Regarding the boot lid - If it unlocks by pushing the boot forward (as mentioned above) you may be able to adjust the latches on either side -I had to adjust one side of mine for it to latch properly .
Good luck
Simon
Post #381845 12th Apr 2016 9:39am
