Home > Technical (L322) > URGENT- Lost ALL ELEC POWER. Solved!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34917 |
check battery , alternator...any belts come off? ... - .- -.
15th Apr 2016 7:14pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3058 |
Hi stan. Can't check batty power as by side of road but all connections good. Belts all ok and alt good just on inspection. |
15th Apr 2016 7:16pm |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 |
It does sound like a total battery fail. |
15th Apr 2016 7:23pm |
could be the 5amp BCU fuse in the main fusebox [under the CD multiplayer] ... - .- -.
15th Apr 2016 7:24pm |
Boxy fuse number?? |
15th Apr 2016 7:27pm |
F ing auto text!
15th Apr 2016 7:28pm |
Do the headlights / sidelights work? |
15th Apr 2016 7:29pm |
Try no 41 |
15th Apr 2016 7:41pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2024 |
Have you any jump leads?
15th Apr 2016 7:47pm |
If you can get hold of a battery, (any type with terminals suited) and a 10mm spanner, (in tool wallet) you have the best chance of getting home.
15th Apr 2016 8:05pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7760 |
No lights on the dash on the lead up to this ?
15th Apr 2016 8:24pm |
I found out, that being a Barclays customer, I have some form of breakdown cover. Ive never used it....as we have green flag anyway, but might get you out of a tight spot. |
15th Apr 2016 8:32pm |
+1 for a goosed alternator and run the battery flat. There is nothing that can't be fixed with a hammer😜😜
15th Apr 2016 8:50pm |
Thanks for all your help chaps. Absolutely no power still. No lights or anything Anywhere except for that repeater! - have AA but had to leave the old girl to get back to my younger girl who was having a bad day with the onboard dolphin boy junior.
15th Apr 2016 9:44pm |
