Home > Technical (L322) > Passenger side door wont lock/unlock after seat / door card |
Why did you remove seat & door card? Have you plugged it all back in correctly? An easy check to make is, does your interior light work when opening that door? If not, your latch is probably unplugged sir |
24th Apr 2016 3:33pm |
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 |
thanks craig the interior light didn't work so i double checked all connections and the white multiplug in the window switch had come out plugged it back in and locks unlocks fine now. didn't think such a thing would make a difference! cheers |
24th Apr 2016 4:03pm |
Glad its sorted |
24th Apr 2016 11:17pm |
