Home > Technical (L322) > EGR warning - post mortem findings |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
And exactly the same thing had happened to the other one. Except this one looks like its been blowing exhaust into the motor housing.
24th Apr 2016 6:41pm |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
Quite interesting.
28th Apr 2016 8:19am |
They hadn't actually failed - the ECU was detecting that sometimes it wasn't getting the full range of movement.
28th Apr 2016 8:56am |
Thanks for that
28th Apr 2016 9:34am |
It's a valve like in the cylinder heads. Basically the motor turns a couple of cogs, that then rotates a the valve stem which has a couple of lugs which run in guides in the casing. As it rotates the stem moves down the case and opens the valve. Ed |
28th Apr 2016 11:51am |
Ok cool. Thanks again |
28th Apr 2016 12:07pm |
gbmud Member Since: 19 Feb 2016 Location: Sussex Posts: 19 |
The Tdci engines in Defenders apparently detect AGR faults - like removal or blocking up - by measuring an expected decrease in the MAF reading when the EGR is open. If the MAF does not drop with the EGR open (as exhaust goes in instead of fresh air) then the EGR must have failed and it shows the MIL lamp. Maybe RRs use the same idea?
29th Apr 2016 7:40am |
That rings a bell Chris. Ed |
29th Apr 2016 8:15am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Can't you get them deleted with a remap..?? Pete
29th Apr 2016 9:26am |
Probably - but then they are there for a reason
29th Apr 2016 1:16pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I would take a look at the slightly smaller version of that engine (V6) the EGR delete re-map is a must do, just because you've got 2 extra cylinders doesn't mean that the V8 will not suffer similar problems to the V6, infact I think that you'll find there are a lot of common faults...... turbo hoses, turbo's and EGR's for a kick off Yesterday I couldn't spell Engineer... Today I are one!
29th Apr 2016 1:25pm |
Very true but they do have completely different layouts which does contribute. The V angle is different to my understanding and because of this the turbos on the TDV8 are lower down because they can't fit them on top. Ed |
30th Apr 2016 9:36pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
The TDV6 and the TDV8 are not related, in any way, shape or form |
30th Apr 2016 9:39pm |
Was always under the impression that they were both developed as part of the Jv between ford and PsA. On he face of it they are completely different as they have different v angles 60deg for the v6 and 90 for the v8.
30th Apr 2016 10:11pm |
