Home > Technical (L322) > Help with part no |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 |
30th Apr 2016 12:58pm |
sparkysteve Member Since: 18 Apr 2016 Location: Cheshire Posts: 10 |
looking at Mircocat its not available as a part, |
30th Apr 2016 8:54pm |
What is its purpose, is it important? Do I need to replace the whole propshaft connector to replace it? 2004 L322 V8 |
2nd May 2016 8:41am |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
The rubber boot/gaiter protects the CV joint from dirt ingress. If it's split or holed then dirt and water can enter which will lead to wear, corrosion and failure of the joint. It will need fixing.
2nd May 2016 2:04pm |
