Home > Technical (L322) > Black smoke, but hoses are OK
Perce
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
After pootling along in traffic for a few miles today, I got the chance to get past a slowcoach at the start of a dual carriageway. Didn't accelerate too hard, but the cloud of black smoke was majorly embarrassing. After getting to a clearer stretch of road I dabbed the accelerator a number of separate times, each time there was a sizeable puff of black smoke, even after giving it a good old thrash to clear out the exhaust. I have recently changed both top intercooler hoses plus the small one to the manifold. Any suggestions as to what might be the cause?
Post #385429 5th May 2016 8:14pm
Try and get it plugged in, to see if it's throwing any codes up.
I would check the hose connections again, though if one has gone or the clip had come loose then you would get a bong. It could be over fuelling, possibly a sticky injector, or Maf issue. Have you tried cleaning the airflow sensor?
Would start there as it's easy. Possibly run some cleaner and see what happens, plugging in is a good idea too. There is nothing that can't be fixed with a hammer😜😜
Post #385439 5th May 2016 9:17pm
Perce
Thanks for the pointers NMJ, a good starter for 10 Thumbs Up
Post #385447 5th May 2016 9:37pm
