Home > LPG > heavy towing on LPG
pinkfoot
heavy towing on LPG
I am in the market for an LPG V8 , in two or three weeks.
I understand some LPG systems revert to petrol when you floor the throttle.
I often tow a 3.5 tonne trailer.
Do you think the LPG system will revert to petrol when pulling this much weight ?
Post #387581 17th May 2016 7:19pm
jambo27
No it shouldn't do. They only tend to revert to petrol when you plant your foot to the floor and the gearbox kicks right down and the mine only switches to petrol when its approaching 4.5 5k rpm. Unless your trying to drag race with it I think there should be no issues. 2008 TDV8
Post #387596 17th May 2016 8:30pm
pinkfoot
Thank you. Good to know.
Post #387599 17th May 2016 8:43pm
Sleeper
United Kingdom 2003 Range Rover HSE 4.4 V8 Adriatic Blue
Ive never had it change when i put my foot down and ive done a few "planted foot to the floor going though the rev range alllll the way" and its stays on gas.
I think a good set up and knowing a gas anorak servicing/updating it helps.
Post #389755 1st Jun 2016 7:56pm
