Home > Technical (L322) > EAS 23.48 bar |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7911 |
Something has gone wrong there it shouldn't be higher that around 190 PSI yours is at 340 PSI....
2nd Jun 2016 2:40pm |
Beemergriff Member Since: 06 May 2016 Location: Northamptonshire Posts: 62 |
Thanks Pete
2nd Jun 2016 3:44pm |
Just poked small cable tie into connector holes at both ends of air-tank. Conclusion, there isn't a non-return valve so sensor is defective and needs replacing. That's about £35 and hopefully I can get one be tomorrow and put it all back together.
2nd Jun 2016 3:53pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
The compressor could not possibly generate 23 bar - nowhere near it!
2nd Jun 2016 3:56pm |
Hi Wealy
2nd Jun 2016 4:36pm |
Sounds like the culprit....
2nd Jun 2016 5:28pm |
So . . Pressure sensor replaced, and valve block too. All put back together but even after reset, still no Air Suspension.
18th Jun 2016 1:00am |
If you get the codes read, or work through the live values you won't be spending good money on guesswork...!!! Pete
18th Jun 2016 10:51am |
Thanks for the suggestion.
18th Jun 2016 1:13pm |
Oh yes, very easy to check the continuity of the wires, I bet they are fine though and the fault lies elsewhere, you have already spent money on a sensor which was probably OK, it is easy to get into just replacing bits you "think" are broken...
18th Jun 2016 6:06pm |
