Home > Technical (L322) > thermostat removal or not |
Personally would not do it. Engine designed to run with a 'stat for a reason. Have you tried / checked your coolant cap?
12th Jun 2016 10:19pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
If coolant is below running (normal) temp the ECU will compensate by increasing fuel thinking it is still in warm up mode. The knock on is high fuel consumption. |
13th Jun 2016 9:11pm |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
hi have changed thermostat for 80 deg no noticeable difference in mpg . lpg changeover time is the same engine def cooler can put hand on top hose now . i have not tried caravan towing yet but will keep posted when i do .engine sounds better and is running great so fingers crossed my mpg is reading 20,4 at the moment and has not changed in 2 weeks give or take .4 mostly urban and a little motorway never above speed limit |
7th Sep 2016 11:57am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
Hasn't this been comprehensively championed by pete/Haylands?
7th Sep 2016 12:07pm |
