Home > Technical (L322) > Part numbers - oil cooler water pipes and thermostat |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7911 |
There are three pipes that run to the thermostat manifold that the oil cooler is fixed to, the thermostat is used to warm up the oil first, then cool it if it gets too hot, it allows water to flow different ways at different times dependent on heat, removing it will result in the three pipes fighting each other and probably won't work....
25th Jun 2016 7:23pm |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 |
HI Pete, thanks for the reply.
27th Jun 2016 6:20pm |
I get trade at a local motor factor so got most of the bit's there... Island 4X4 are usually amongst the cheapest to get the parts though... Pete
27th Jun 2016 9:16pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Here's a link that may help.
28th Jun 2016 12:47pm |
