Home > Wheels & Tyres > Anyone ever refurbed alloys themselves? |
LROMAD Member Since: 10 Oct 2015 Location: Cheshire Posts: 54 |
Hi, if you are planning to spray your wheels, it would be wise to find your local paint /body shop suppliers .They can help you with the paint.I would avoid painting small areas of your wheel ,as it will probably turn out patchy.Give the wheels a good wash before starting the paint preparation process.Carefully preparation and patience will give better results.You can buy wheel silver/lacquer from halfords but colour matching could be hit or miss .As with most paintwork, it boils down to your ability,working environment and time to get good results.Have a look on you tube to get some tips.Just read your post again,it might be possible to just colour the rim and lacquer all the wheel but it s difficult to say how successful it would turn out . Ray |
24th Jul 2016 10:43am |
Yes I have but definitely not with a rattle can. I use a relatively cheap touch-up spray gun (Sealey) but of course you need a compressor to do this. My results were just fine and as noted above, buy the paint from an auto paint factors.
24th Jul 2016 10:49am |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 |
Sparkle silver |
24th Jul 2016 4:05pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Done several sets, good rub down finishing with wet and dry. Good clean and you are good to go either to a paint shop or as I did with Hammerite smooth on top of Hammerite primer both from rattle cans and remarks like how much they charge you for that finish says it all.
24th Jul 2016 5:37pm |
