Home > Technical (L322) > Graunching Steering on Left Turn Only - PLUS ->
Now I don't know whether this is as a result of the weather turning colder, but this has only just come about since we got down to 0 degrees.
Have scoured forum, and found these two posts that may be related:
http://www.fullfatrr.com/forum/topic1632.html?highlight=steering
http://www.fullfatrr.com/forum/topic998.html?highlight=steering
Problem 1
Turning the steering wheel to the left, whether standing still, moving forwards or reversing, I get a loud (even inside the cabin) graunching/creaking noise from the steering - seemingly on the left side. This only makes a noise when turning to the left, not when returning from the left lock to centre or when coming back from right lock to centre.
Had track control arm fitted to drivers side 6 months ago.
Steering itself seems fine, no problems, wobbles etc when normal driving.
Problem 2
When moving off after about 20 yards or so, I get a knock from underneath ( I can feel it under my left foot). Doesn't seem to be gearshift related ( new gearbox 1.5 years ago)
Problem 3
Knocking and creaking noise from passenger side rear, but not necessarily related to going over bumps, and somehow seems to be linked to Problem 1 when turning left
Looks like ball joints, track control arms, but anything else I should worry about? Big Cry .
Post #39701 27th Nov 2010 1:20pm
Problem 1 sounds like our old enemy ball joint Big Cry
Problem 2 I couldn't say, you would be best get underneath and see if anything is loose or touching the bodywork
Problem 3 There are several bushes on the rear suspension that wear out and could possible need replacing
Post #39705 27th Nov 2010 1:35pm
Thanks 47 - I'll report back once its been into the tame mechanics for inspection. want it to warm up a bit now, just to see if any of the problems go away with warmer weather Confused .
Post #39823 28th Nov 2010 11:12am
If it is a ball joint you're best getting it done as soon as possible.
Once they start creaking they are on the way out
Post #39825 28th Nov 2010 11:18am
Must have the "self-healing" option pack on my FFRR, as all problems and noises went away 5 days ago, even with the temperatures down at sub zero still. I'll still be getting it looked at Rolling Eyes .
Post #41849 11th Dec 2010 12:13pm
If there is a lot of water on the roads or damp conditions the noise could seem to disappear as the water lubricates the joint. A few dry days soon dries it out again and the noise re-appears Big Cry
Post #41862 11th Dec 2010 2:29pm
