![]() | Home > General > Mileage: 170,000 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Yes, just passed the 170,000 mile mark today |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 613 ![]() ![]() ![]() |
just run in joe |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Not far beyond - just turned over 164,000 this evening - doing 22k a year. Sailed through MOT last month with just an advisory on a rear suspension bush. Current Fleet:-
Front and rear subframes are the things that will go, i've spotted even on mine while it may be surface rust it still gets in.
I have less fear about dropping the rear subframe given all the fiddling about I have done at the rear end (ooer!), how easily does the front one come out? Could I do this on my drive?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8741 ![]() ![]() ![]() |
Front should be fairly easy, you just need a framework across the suspension tops to support the engine... |
As above Joe |
If it's got all new bushes on it then gotta be worth it for that price to save faff with bushes as a direct boot over swap ![]() Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Yes they are Will... All the same exept the later Derv frames have extra exhaust hangers attached ![]() |
Are the rear diffs the same as well? Extra hangers makemo real odds as you don't need to use them |
Sorry Will, i was referring to the front subframes being all the same no matter what the engine fitment |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I'm on 166k. All three mots I've done on it since owning, apart from the first, (bought with no mot) have passed, with this year getting an advise on the front discs. (Done) and the under tray had a couple of bolts missing!
MOT guy suggested I went at front and back with an air needle gun to knock off all the loose.
How much would it be to sand blast it if you tooo it off the car though as that could only be 15mins work for someone and save a lot of time for you but does mean fully taking it off and you can note the areas to really coat it up as well as I'm sure some bits suffer more than others... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
