Home > Maintenance & Mods (L322) > tow bar |
eBay is your best bet - Expect to pay around £50 for the armature that goes behind the bumper. £50-£85 for the electric sockets and £50-£65 for the towing ECU/Module. Then you have to choose which tow-bar you want. These range from £30-150 depending on if you want a standard drop plate or removable one.
30th Nov 2010 10:54am |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
I believe the armature's are slightly different from 03/facelift models - sure someone wiser on here can confirm - so do be careful if that is the case - most ebay seller's dont make it obvious... |
30th Nov 2010 12:27pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Yes - the armature is different for pre/post 06MY
30th Nov 2010 1:10pm |
If being fitted by a garage, they should be able to overcome the differences by grinding wrong mounts off if they get in the way and creating some new ones in the correct place. |
30th Nov 2010 1:40pm |
Yep, they could be adapted if required, but worth being aware that there is a difference as not many sellers do |
30th Nov 2010 1:41pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
I fitted a new westfalia detachable towbar on saturday. I sourced mine from towequipe, i bought the 13pin factory electrics kit. Everything you need including the detachable bar holder that sleeps in the offside boot cubby hole. Not cheap but the same as oem. The westfalia pieces you speak of are removed during the armature fitting process http://www.westfalia-automotive.de/fileadm...320051.pdf Ian |
30th Nov 2010 9:28pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2030 |
Give these guys a call, sorted me out
30th Nov 2010 10:07pm |
tommac22 Member Since: 10 Nov 2010 Location: devon Posts: 55 |
thanks for all the responses will get in touch with the suppliers mentioned and hopefully they can sort a bar out! |
1st Dec 2010 12:06pm |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
Sorry to drag up an old thread, but can anyone tell me if the "dedicated electrics" sold by PF Jones includes the genuine LR control unit? Or is it an aftermarket unit? |
14th Jun 2011 11:47am |
I called them up and the answer is it is not OEM. I've seen a few recommendations for PF Jones on here but in the last two conversations I've had with them they've been next to useless. first time they wouldn't take an order over the phone, preferring me to use the web site, and second time they didn't know what I meant by "OEM"! |
14th Jun 2011 3:03pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
I found them very helpful on the phone so maybe it depends who you speak too
14th Jun 2011 7:04pm |
Agreed, I bought the hardware from PF Jones. Another question - is the wiring loom different for the 02-05 versus the 06-09 MY's ? I picked up a loom and ECU from ebay for just less than the price of a new ECU but I just noticed it's listed as an MY06-09 loom. |
14th Jun 2011 8:49pm |
Well, the loom arrived and I fitted all the hardware and electrics today. Glad I have air tools as on my 2003 car the big bolts holding the bumper supports on were a bit tight, since they've obviously never been removed. Reason for me replying here is in case anyone else has a similar question. The loom fitted and worked fine even though it was listed as being for a later car. I had searched around a bit and could only see one part number for all years anyway so I was in the end fairly confident it would work. Oddly the Land Rover instructions mentioned a relay to be plugged into the loom, but no relay present and no place to plug it into either. All works fine regardless anyway, with the proper OEM towing module. Loom and module was a bargain at £60! |
18th Jun 2011 8:51pm |
