Home > Maintenance & Mods (L405) > L405 removing headlghts procedure?
JCW
United Kingdom 2012 Range Rover Autobiography TDV8 Sumatra Black
Can anyone help with the correct procedure to remove the headlights on a 2013 L405 please?
Assuming the front bumper requires removal first but wanted to check.
Thanks.
Post #402227 27th Aug 2016 2:56pm
andy2577
United Kingdom 2014 Range Rover Autobiography TDV6 Santorini Black
Front bumper needs to be removed as well as the grill
There is a bolt underneath the wing which is easily seen when the bumper is removed , then there is one under the grill again easy to see once removed and the two on top of the slam panel
But Take extra care as the brackets on the headlights are extremely flimsy and break very easily ! 2002 - Blue L322 3.0 TD Vogue (Previous)
2006 - Black L322 4.4 V8 Vogue Autobiography (Previous)
2014 - Black L405 3.0 TDV6 Vogue Autobiography (Present)
Post #420751 2nd Jan 2017 4:15pm
