Home > Maintenance & Mods (L322) > Headlights 2012 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34871 |
i cant magnify the picture properly but could that be the lever for uk/europe beam setting... ... - .- -.
30th Aug 2016 10:23am |
It's just the shutter that creates dipped beam wobbling a little when it's down , both high and dipped beam are provided by the HID lamp via an internal shutter that drops down and it will rattle a bit on rough roads . The high beam lamps are just halogens to flash and do a little bit of short range filling in , their parabola is not designed to throw light down the road .
30th Aug 2016 10:49am |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Many thanks for your replies but in attached video levering of headlight is done from another switch which,as u see video,is located on the right hand side and not from the white plastic one which is on the left side
30th Aug 2016 12:40pm |
Your headlights are two models previous to those lights sir 2008 MY Supercharged
30th Aug 2016 1:13pm |
Thanks axle confused because 2010 headlight also has the white plastic switch so thought would be the same. |
30th Aug 2016 1:39pm |
I am quite confused with head lights (the ones with black plastic insert)
30th Dec 2016 4:03pm |
