Home > Technical (L322) > Windscreen Washer Fluid Level
Just a quick warning to check the level of your Windscreen Washer Fluid as if its nearly empty (or empty) the fluid can run back out of the pipes leaving them "Non primed" and allowing the pipes and nozzles to freeze. Once frozen they are very difficult to defrost with the temperature below freezing making driving on salted roads impossible.
I just picked up a 2007(57) Vogue TDV8 which had been allowed to run dry and after filling with washer fluid I had a very "Interesting" journey round the M25 from surrey with a very smeared windsreen and frozen nozzles.
To fix I poured warm water over nozzles and hand squeezed the freed pipes under bonnet to find remove any frozen sections. Only after about 15 minutes with the engine running did they finally start working again.
Be warned keep it topped up Thumbs Up
Post #40550 2nd Dec 2010 6:18pm
dan_uk_1984
The nozzles themselves are heated, and the system has a 1 way valve in so the tubes should drain back into the tank... However if you dont use anti-freeze in there then the 1 way valves get damaged and as you say all the fluid will drain out of the lines...
Post #40551 2nd Dec 2010 6:41pm
Fox
Re: Windscreen Washer Fluid Level
One of the high milage ones you asked about?
Post #40552 2nd Dec 2010 6:56pm
No this is 42000 fsh unmolested original Vogue in beautiful condition in Silver/Jet/Burr-Walnut.
Very pleased with it. Thumbs Up
Post #40557 2nd Dec 2010 7:37pm
Thanks Dan I did not know the technical reason but as the tank was dry and the system did not work after refilling I figured "frozen" as the car was covered in deep snow when I collected it. It started working after poured warm water on nozzles and I hand massaged the tubes after refilling it with Screen wash. Perfect now Thumbs Up
Post #40558 2nd Dec 2010 7:40pm
dan_uk_1984
Most screenwash is barely frost proof, the stuff you buy in the petrol stations is generally only good for -5, and even then there is a considerable amount of "slush" in the fluid that will block the pickup filter.
The ones that advertise protection to -45c! only give that level of protection if used neat. And that gets expensive!
Post #40568 2nd Dec 2010 8:21pm
mine tells me when its low on washer water... Thumbs Up ... - .- -.
Post #40570 2nd Dec 2010 8:24pm
M44K TS
So far my ingenious mix of water and meguiars hyper wash car shampoo has worked a treat, no smearing, hasn't froze up at all and makes for some interesting frozen bubbles. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #40572 2nd Dec 2010 8:27pm
Yes they all do Scarey but this one was at a dealership and they could not be arsed!
Post #40581 2nd Dec 2010 8:59pm
Sportex
England 2008 Range Rover Vogue TDV8 Stornoway Grey
as my washer bottle has no bumper in front of it, it is permanently frozen solid Big Cry No body told me there would be days like these
L Reg dark purple/burgundy sort of Disco
R Reg very red disco
Bright Silver disco TD5
Sort of bright girly powder blue disco TD5
Gone (a while back) 1999 P38 4ltre Autobiography. 13 miles to the gallon, 10,000 miles to the engine
Gone MY06 RRS HSE Rimini Red
Gone MY10 RRS HSE Purple
Gone 2007 TDV8 Vogue OF Stornoway Grey (In Love again)
2011 4.4 TDV8 Vogue Baltic Blue
MY66 VOGUE TDV6 3.0 Red
Post #40617 2nd Dec 2010 11:53pm
GJOB
2005 Range Rover Vogue SE Td6 Java Black
Heated you say? Mine are hit and miss in this weather even with a full bottle of screenwash in it....
Anyway to test if they're operating as intended?
Post #40638 3rd Dec 2010 10:27am
dan_uk_1984
As a cost of around £6.00 I would nust replace them anyway. I supose you could measure the resistance or something?
http://cgi.ebay.co.uk/Genuine-Range-Rover-...56405809bb
Dan
Post #40662 3rd Dec 2010 1:08pm
GJOB
Dan
Thanks dan, i'll save this link and will try and confirm if they're busted first. Cars going in for a MOT next week so will add this to the list Thumbs Up
Post #40842 4th Dec 2010 6:17pm
Still can only get one washer jet to work , drivers side just not working at all have tried the guitar string method , the compressed air method ............ Nowt Neutral
Post #40844 4th Dec 2010 6:25pm
