Home > Maintenance & Mods (L322) > Oil cooler pipes which way round 2003 4.4v8 ZF5HP24A |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
Hi, I'm doing lots and lots of work on this vehicle and one of them is full gearbox service. I'm changing the oil cooler, stat and cooler pipes along with the main radiator as part of the work. It's a job that's took a while as have to keep coming back to it weeks after starting. Now I've fitted the new oil cooler pipes to the gearbox and routed them to the new oil cooler but can't remember which way round they push on. Does it matter, I would imagine it does and don't want to get it wrong and starve the gearbox of oil, is the cooler a one way flow etc?
23rd Sep 2016 12:56pm |
So your saying that the last diagram is the correct one? That's what i think to, the the one with the gearbox picture is incorrect. 2004 RR 4.4 V8 Autobiography |
25th Sep 2016 2:33pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3192 |
Don't know if this takes you any further forward. http://www.rangerovers.net/forum/6-range-r...ooler.html
25th Sep 2016 3:03pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 911 |
These two diagrams (from RAVE and Microcat) seem to tie up, at least. The hot oil leaves the transmission from the port on the left hand side of the casing (the pipe with the banjo bolt) and returns to the transmission, after passing through the cooler, through the pipe that screws into the front of the transmission on its right hand side (facing forwards)
25th Sep 2016 5:50pm |
Thank you Phil, that's the info I needed to confirm. I have the pipes sat just over the ends ready to push on just needed to double check I was correct before pushing them on.
25th Sep 2016 9:44pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
Had these pipes off today and can confirm that bottom drawing is correct and first drawing is wrong. Just remember, banjo to the right ! |
17th Aug 2017 12:10am |
