![]() | Home > Maintenance & Mods (L322) > '07 ventilated/cooled seats in and '02 |
No Dan, in simple terms... Everything is different from the electronics to the car floorpan... The 07> seats will not even bolt to the floor as the floorpan changed when the seats were equipt with airbags... |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Ok great what about from a 55plate ventilated seats - same problem? They look a bit newer than the ones I have |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
At the rate you're going, you'd be cheaper buying a newer Vogue SE |
Yes 06my seats will fit as they are the same fitment between 03-06my's ![]() |
Great - how about the controls for cooling? |
