Home > Technical (L322) > Aux Heating |
Jase71 Member Since: 13 Apr 2016 Location: Portsmouth Posts: 479 |
Just blowing ambient temp air this morn with no warmth.. |
13th Oct 2016 3:31pm |
Got the FBH to start firing up including clicking and small puff of smoke but it then shut down with a low crackling sort of noise. Tried it multiple times but did the same thing.
14th Oct 2016 3:57pm |
krisleeds Member Since: 19 Oct 2014 Location: leeds west yorkshire Posts: 60 |
I feel your frustration.
16th Oct 2016 1:16pm |
Thanks Kris. Misery loves company
16th Oct 2016 1:36pm |
Ha im the same. If it's fitted and supposed to work i will try my best to get it working. I try every morning.
16th Oct 2016 1:50pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
May not work, but set your heater controls to a highish temperature and pull and replace the fuse. Apparently you need to reset after three failed attempts. Use the screen controls first. Leave the remote till you have got it working.
16th Oct 2016 1:51pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 761 |
I am getting the same problem with my FBH.
16th Oct 2016 1:54pm |
-20 Celsius.
16th Oct 2016 2:00pm |
As I mentioned above, + 1 for vehicle battery charge state. I take it also that you are aware that the Park Heater will turn off if the ignition is on?
16th Oct 2016 2:08pm |
thanks. kept mine on battery conditioner all day/overnight just in case and new batteries in remote..also try manual start on console a number of times.
16th Oct 2016 2:12pm |
Can you smell any fumes by the front left wheel arch? Any smoke coming out ?
16th Oct 2016 4:23pm |
I can smell the fumes but only a small puff of smoke after it shuts off from an aborted start 😔 There is definitely a plastic creaking sound when it aborts.. |
16th Oct 2016 8:37pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
its that time of year again
17th Oct 2016 5:26am |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
These units are real simple. If your getting the clicking and a smell of fuel, all thats left is the glow plug. The burners have a gauze in them that the fuel gets fed into which is then ignited by the glow plug. Ill wager the gauze is clogged or you have a duff glow plug. No7 - 2003 V8 Vogue |
17th Oct 2016 5:12pm |
