Home > Technical (L322) > key synchronization issue |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
If using the IIDTOOL make sure it has a software update and your phone app is synced with the device after the update (assuming you use the IIDTOOL with a phone app). ______________________________
12th Oct 2016 9:56pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I've not got my iid tool yet only a basic icarsoft..the iid tools here shortly! Ive synchronized it via the keyfob procedure..it doesn't work anymore though...going to defo try a battery disconnect first...already tried replacing keyfob batterie..failing that will order a rf receiver from ebay and try that!...defo something to do with me rapidly locking/unlocking car 3/4 times at once.. |
12th Oct 2016 10:10pm |
Tried a battery reset! Just as I thought nothing! Found lots of rf receivers on ebay for sweeties..thinking of replacing it in the hope its that that's decided to stop working..failing that is there a newer version available? Process of elimination again |
13th Oct 2016 7:23pm |
