Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3672 |
Thanks for your reply Cass.
7th Nov 2016 6:54pm |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 |
I had a similar mod done on my Disco 4 and that was done under a TSB and paid for by Land Rover as it was considered a "design" issue. My understasnding is that this issue on the FF is also a"design" issues and the fix is also a TSB. Land Rover Approved, who are the warranty company within Land Rover, will not pay for work done under TSBs. However, Land rover only pay if the car has a Land Rover or Land Rover Approved warranty currently running on the car.
8th Nov 2016 10:38am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
any news on the drain valve modification yet Mike? ... - .- -.
14th Nov 2016 2:02pm |
My car is booked in on 1st Dec. For the dealer to have another look.
14th Nov 2016 2:22pm |
Mike, ring LR assist and tell them you get loads of smoke when you accelerate over 2500rpm, they will tell you to book in at a dealer which you tell them you have....this way when the dealer rings up for authorisation, LR will know about it and will be more likely to do the job under warranty.... ... - .- -.
14th Nov 2016 3:18pm |
After several attempts, LR Approved would not approve the mod, but Finally LR have agreed to fund the work as a "Good will" gesture. It is now booked in for the work early in the New Year.
16th Dec 2016 2:29pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
Well done Mike.
16th Dec 2016 3:12pm |
nice one Mike.... ... - .- -.
16th Dec 2016 3:19pm |
MOT smoke test procedure.
16th Dec 2016 3:23pm |
I have just picked up my car after completion of the work.
6th Jan 2017 5:08pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
Just had local dealer test drive mine and agree that it needs doing. Just got to give them a few days to get whoever in LR to agree to the work. They did say that warranty wouldn't cover it as it's not a failure. Regards
13th Jan 2017 2:57pm |
I was told that LR Approved warranty does not cover it, but that LR will only cover work on cars still in warranty, so my advice to anyone would be to get it done before your LR Approved warranty expires. Presumably this applies to early L405's as well. G reg 2.5VM Vogue Portofino red 1991- 1999
13th Jan 2017 3:05pm |
13th Jan 2017 3:58pm |
interesting to know how proser gets on, I'm presuming you are in the same position as me with an expired LR warranty but an AUC warranty still in force. In which case i need to figure out how to make it smoke.
13th Jan 2017 6:55pm |
