Home > Wheels & Tyres > L322 18" or 20" |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
First off, welcome to the forum.
30th Oct 2016 9:56am |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
Wheel nut change from earlier to later cars, not sure when.......
30th Oct 2016 9:57am |
sam919 Member Since: 21 May 2016 Location: south lanarkshire Posts: 7 |
Hi, thanks for the input.......missed the important details.
30th Oct 2016 10:11am |
Biffo Member Since: 26 Aug 2016 Location: Wiltshire Posts: 82 |
I have 18's on mine and think I will probably stick with them as the country roads I mainly drive on are pot holed. I wonder if the lower profile tyres give the suspension ball joints and bushes a harder time ? |
30th Oct 2016 10:14am |
For your purposes I would recomend 18" with slightly oversized General Grabber AT's , not much is going to stop you then and very hard wearing . 2008 MY Supercharged
30th Oct 2016 10:20am |
Ok, what size would you recommend ? Over the norm
30th Oct 2016 10:26am |
I have never run 18" so not sure but some one who does will be along soon but at a guess say 255/18/55 if that is even a proper size . 2008 MY Supercharged
30th Oct 2016 10:28am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I'd stick with standard 18" set up, with 255/60/18's, there is no way you should think about bigger tyres if your going to be using it for heavy towing... it struggles enough with out playing around with the overall gearing.
30th Oct 2016 10:47am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I have 265/60/18s (with Compomotive rims) as they are a pretty common tyre on several Japanese 4WDs.
30th Oct 2016 11:23am |
It seems to be pointing that way, I have 20" at the moment.
30th Oct 2016 11:28am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3055 |
@sam919,
30th Oct 2016 12:08pm |
rar110, the difference between 265/60/18 and 255/60/18 is 10 mm in width and 6mm in height... your tyres are 6mm or 1/4" bigger... sod all in the grand scheme of things, and if Jap sizes are easier to get over there, stick with'em
30th Oct 2016 12:41pm |
Miggit
30th Oct 2016 12:59pm |
Thanks for all the suggestions and input. I think I'll go with 18" and look for a full set with decent tyres, the 20" I have on now I'll try and move on once done.
30th Oct 2016 7:28pm |
