|  | Home > In Car Electronics (L322) > Aux port upgrade |
| jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62      | I'm trying to work out how to do the same thing mate - let me know if you figure it out....
|  28th Nov 2016 10:05pm |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136      | Which one is MOST - I get confused - is that the BMW electronics ?
|  28th Nov 2016 10:08pm |
| jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62      | As far as I'm aware MOST is the fibre optic system that came in MY05 ish - not sure if its of BMW heritage or not.
|  28th Nov 2016 10:16pm |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136      | Sounds like the Ford system then
|  28th Nov 2016 10:18pm |
| Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608      | Your best option for the MOST system with the Touchscreen is to fit the Auxiliary Connectivity Module (ACM). Dan at Duckworths has them at a more realistic price than the RRP  | ||||
|  29th Nov 2016 2:11pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | do you not have an 3.5mm aux port already in the rear of the centre cubby? I thought all the most equipped cars had this? There is nothing that can't be fixed with a hammer😜😜
|  29th Nov 2016 5:44pm |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277      | The earlier ones definitely didn't have it. I put in a system I got from Germany. Did a write up.  Not sure when the aux port as standard came in. John
|  29th Nov 2016 6:18pm |
| Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 300      |
 Brilliant thanks very much I am just waiting for Father Christmas to turn up with a 💷 Notes so I can get the nessary parts will keep you updated 👍 | ||
|  30th Nov 2016 8:56pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
 you also have to get creative with the location of the ACM control module behind the glovebox as there is very little room and the recommended location for Aux input/usb unit itself doesn't work with the earlier glovebox design
