Home > Wheels & Tyres > air jack |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 |
http://www.ebay.co.uk/itm/4t-ton-Exhaust-J...Sw4GVYHNCQ has anyone tried one of these just wondering if would be ok to use if needed to change wheels ??? |
12th Nov 2016 4:37pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
In a word NO
12th Nov 2016 5:06pm |
had one years ago on a series 2a worked great is there a major problem with just connecting to one exhaust ? |
12th Nov 2016 11:42pm |
Only in as much as the system is not a true twin system, and the rear box has 2 pipes.. as the air bag needs pressure to inflate it, and one side of the box is open, there was a though "is there enough pressure" from what will effectively be a leaking exhaust... and then there is still the issue of getting at the bloody pipe to start with.. they have sort of hidden it up behind the rear wheel, not exactly use friendly..... Yesterday I couldn't spell Engineer... Today I are one!
13th Nov 2016 12:04am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
I have one but I wouldn't use it to change a wheel. It's a recovery device when one is bogged. But as said above, the twin exhaust outlet could be an issue. I haven't tried it with the L322. Ron B. VK2OTC
13th Nov 2016 12:18am |
ok cheers think il get one and try it and report back I can always use it on another motor or as afloatation aid in one of my boats |
13th Nov 2016 12:23am |
Many many years ago someone here was going to experiment with lifting bags and using a plumbers pipe bung cut down to close off one of the pipes but I don't remember the outcome if any . 2008 MY Supercharged
13th Nov 2016 1:09am |
I have a vague recollection of that one too.. Seeing as we are both in the dark.. I would assume that it wasn't successful ...........
13th Nov 2016 8:47am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
We used to jam a potato into exhaust pipes for other reasons when I was a kid
13th Nov 2016 10:21am |
13th Nov 2016 10:24am |
