Home > Technical (L322) > strange data |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 |
wowser 43.3 odd volts opps !!!!! |
18th Nov 2016 9:18pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Car seems to go through the stages in the eas without any issue..doesn't seem to be any noticeable diffrence in heights in each corner although the back of the cars a bit lower...strange one |
18th Nov 2016 9:29pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
It's a hall effect sensor, it can't make volts...!!! It gets supplied a voltage (5volts IIRC) and returns a different amount depending on where it is, the readings will never be the same and they don't have to be, it's a relative measurement...
18th Nov 2016 11:44pm |
Clever stuff! Used the same machine that has also gave me problems measuring the reservoir pressure readings.I used it on my mates l322 and it gave both of us 11.67 bar readings..? Both cars have new compressors and his has a new reservoir..the fact both our readings where identical kind of disheartened me..its been a great wee tool to help learn diagnostics but fails when it cant read certain faults or do functions I need...my machine could be simply be faulty but I now realise i should have invested in an iid tool after I was advised on here.. Cheers pete |
19th Nov 2016 12:22am |
Best £400 you will ever spend if you want to keep one of these long in the tooth FF's on the road... Pete
19th Nov 2016 1:00am |
Biffo Member Since: 26 Aug 2016 Location: Wiltshire Posts: 82 |
Mine shows a similar reading - I have 3 sensors reading around 1 - 2v from memory, but one was reading 32v ! But the suspension works fine, so I've not worried about it. I was using my Foxwell NT644, but I've just invested in an IID as well. It will be interesting to plug that in and see what it shows (when it arrives). |
19th Nov 2016 11:55am |
I'm the same..if the iid tool helps me diagnose my heating issue and re calibrate my eas heights and a couple of other issues its paid for itself straight away..I'm ordering the Bluetooth one today.. |
19th Nov 2016 12:16pm |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Did you have any luck with this? My front LH sensor was showing between 30 and 40 volts, i've just replaced it now with a genuine LR height sensor and it's still reading it |
5th Jan 2017 7:55pm |
Yeah it was was a fault with the icarsofts readings.. just got an iid tool from santa and readings are normal. Still think the icarsofts a decent introductory data reader but I've found mines has been wrong on a few different issues.. |
5th Jan 2017 8:42pm |
Well that makes it pretty useless then, if it can't even give a correct live value you're better off not having anything at all...!!! Pete
5th Jan 2017 8:56pm |
Oh
5th Jan 2017 8:59pm |
It could be the wiring loom from the height sensor, the bit you plugged into, they are well known for internal breaks or corrosion, so much so that they make a part loom replacement to splice in...
5th Jan 2017 9:04pm |
Absolutely spot on Pete :thumbs': all it's been good for was resetting the eas after it was overhauled. Stacker . Out of curiosity what does the i930 give you as a reading for resovoir pressure? Mines was miles out on it. 10 and half bar if I remember.. really poor imo.. |
5th Jan 2017 9:10pm |
Well I visited my LR techician friend tonight, he had his Snap on Solus diagnostic machine!
5th Jan 2017 11:44pm |
