Home > Technical (L322) > Idle problem |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Could be air leak in the vacuum system somewhere, there are a few small pipes that are vulnerable
29th Nov 2016 9:29pm |
Skip720 Member Since: 12 Jun 2016 Location: Wakefield Posts: 32 |
I have the I car soft thing . How would I use it to find out? |
29th Nov 2016 9:56pm |
Never used the icarsoft but would expect you connect it to your OBDII port and scan engine ECU
29th Nov 2016 11:09pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34920 |
i'm sure someone has, do a search ... ... - .- -.
29th Nov 2016 11:13pm |
29th Nov 2016 11:15pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
You can check maf readings in it no probs..select engine, select data stream and mass air flow readings are there...you can also select obdii diagnose and select it from there in either numerical readings or via graphs! |
29th Nov 2016 11:41pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3059 |
Sounds like the MAF. Mine was dirty so I replaced it with a new one and she purrs nicely at 750 rpm now. |
30th Nov 2016 10:22am |
Thanks guys. I will have a look tonight.
30th Nov 2016 3:00pm |
