Home > Wheels & Tyres > Will smaller 18's fit over the Supercharged discs? |
Trying to eliminate this drone/noise I'm getting and according to this TSB there can be an issue with the 20" Alloys.
1st Dec 2016 9:51pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7905 |
Not the standard 18's apparently... Pete
1st Dec 2016 10:12pm |
19" or Compomotive 18" only 2008 MY Supercharged
2nd Dec 2016 1:40am |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Compmotive ones should fit, best price I've seen is going direct. I think you'll be ok on an FF but the sport has a weight / damper that needs to be adjusted in order to get it to clear. Ed |
2nd Dec 2016 7:43pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1233 |
Stock LR 18's will not fit.
2nd Dec 2016 11:02pm |
I'll only be fitting them to rule them out as the cause of this reverberation through the car - not a permanent change. If it turns out the noise goes away I'll fit the required Harmonic Damper.
2nd Dec 2016 11:18pm |
The suspension setting for the supercharged V8 transmits a resonant frequency from the 20 inch wheel/tire assembly to the vehicle body. This resonant frequency coincides with the natural frequency of the body cabin, resulting in the audible drone.
3rd Dec 2016 1:17am |
I still stuggle to figure out how a wheel which should be balanced can transmit vibrations enough to cause a reasonance in the cabin - or that wouldn't happen across all wheels?.
3rd Dec 2016 9:59am |
I think you might have to be careful over which 19" you go for as well. Post 2007 are all ok I think, the ones from before the facelift may not fit, think it's to do with the curve on the inside of the alloy.
3rd Dec 2016 11:27am |
