Home > Technical (L322) > oily diff |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
Remember Range Rovers don't leak, they just mark their territory ______________________________
3rd Dec 2016 6:59pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Brilliant! |
3rd Dec 2016 7:16pm |
3rd Dec 2016 7:42pm |
Check the breather's aren't blocked |
3rd Dec 2016 9:13pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Is it dry higher up? |
3rd Dec 2016 9:25pm |
Just been out with a torch and visibility's better...bit oily above it as well..looks dirty above it and oil on diff looks cleaner? |
3rd Dec 2016 9:31pm |
Managed to get car up on ramps today..looks like oils coming from higher up...signs of an old leak on the rocker covers...zero oil ever on my drive but underside of cars quite messy...
4th Dec 2016 5:44pm |
Well good and bad news. Good it does not look like a diff leak. Bad it could be from the upper engine as you have hinted.
4th Dec 2016 5:53pm |
Everything's crossed ..oil levels don't drop dramatically tbh..not a drop in the ground in over 6 months of ownership..looks like its been happening for a while..first time I've been under the car and I was shocked at the mess...last owner never cared about the fatty by the look of it...im determined to get her mechanically perfect...I'm a big fan of the cars and it makes me smile everyday...even with its niggles
4th Dec 2016 6:08pm |
The mess under the car could be the small 4" pipe from the oil separator. Mine was like chewing gum and had a small split in it. This was leading to the oily gunge coating everything underneath, but strangely like you, not a drop on the drive...
4th Dec 2016 6:22pm |
Fingers crossed its that as its getting done next weekend ... After that I will contact Duckworth's and source rocker gaskets as there's signs of an old leak on both sides..ta |
4th Dec 2016 6:30pm |
Good luck my friend. I'm going to do the air sus compressor next weekend, I've noticed it's a bit slow getting up to off-road height. It's not noisy or anything so looking at it as a bit of preventative maintenance.... ______________________________
4th Dec 2016 6:37pm |
Thanks...i quite enjoyed stripping the compressor down myself..my piston chamber was too badly scored and it didn't help me..hopefully you have better luck my good man |
4th Dec 2016 6:41pm |
Mm fingers crossed ______________________________
4th Dec 2016 6:45pm |
