![]() | Home > Technical (L322) > Normal Height only then red triangle/ Don't exceed 30mph? |
Indicates you've hit something ... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Have you got a fault code off it Ryan?
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1416 ![]() ![]() ![]() |
Or maybe problem in towing electrics making the car think a trailer is attached? Only Range Rovers since 1988 |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Do the later cars have the height lock function? ie have you pressed the centre of the button and locked the system? Yesterday I couldn't spell Engineer... Today I are one!
Thanks all. Will check |
Hi, this issue has progressed. Not had a chance to try your solutions yet but this afternoon the car has lowered to just above the tyre tops, it is bouncing all over the place at 25mph and a red warning triangle advises don't exceed 30mph.
The car having lowered and wallowing about suggests compressor problem or air leaking from somewhere, it is presumably sitting on the bump stops?. I'd proceed to workshop, under own steam if realistic distance, otherwise on truck. Depressing this is happening on a 2012 car. Only Range Rovers since 1988 |
Time to call LR assist.
Thanks for the replies.
don know if the lock to lock works on our later cars Ryan? Did you have any success. There is nothing that can't be fixed with a hammer😜😜
The car does recognise the lock to lock reset attempt but nothing happening other that the warning 'suspension fault' !!
"suspension fault".....i had that too on mine, but it would move up and down. Was a hole in the front bag I could hear it on up Height...
Cheers Mark |
