Home > Maintenance & Mods (L322) > door cable
vmaxer
United Kingdom 2003 Range Rover Autobiography Td6 Cairns Blue
door cable
ive been having trouble with the rear windows lowering on there own while driving even with rear window lock on,so today i decided to take the door panels of to check the wiring [all 4] Very Happy not found any wires touching or broke ,the trouble now is how the hell do you get the cable back in the handle Censored Censored Censored Evil or Very Mad ive hadto sit with my harley running to calm me down Sad
Post #418002 15th Dec 2016 2:06pm
Mr Tee
Its a basturd , I did it by absolute blind luck, not much help sorry, but I feel your pain. At least you didn't fit a new cable wrongly which pinged off when the door shut and you then had to bend the door card to get the fecker off.. Big Cry
Post #418027 15th Dec 2016 4:19pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Offer up the door card and make sure the inside handle is pushed in, then insert the black plastic end in and it should clip in,
I know its a pita, but practice makes perfect. Very Happy
Post #418036 15th Dec 2016 6:01pm
alistairh
Post #418041 15th Dec 2016 6:55pm
vmaxer
cable
thank you thank you thank you Bow down Bow down Bow down Bow down sorted Thumbs Up
Post #418137 16th Dec 2016 2:31pm
alistairh
Post #418147 16th Dec 2016 3:13pm
miggit
Re: door cable
One of my pals has this problem with his ffrr.. turns out that it's the cable window regulator slipping, and the only fix is a new regulator... and according to my pal it's a rather involved job Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #418480 18th Dec 2016 4:05pm
Dolphinboy
United Kingdom 2011 Range Rover Vogue TDV8 Atacama Sand
Changing regulator is not as bad as u think miggit. I did it myself and it took a coupla hours but then I am a complete numpty when it comes to things like this. But all good and all working fine.
Post #418527 18th Dec 2016 8:07pm
miggit
I just don't understand why the glass has to come out Rolling Eyes Rave isn't very clear on why, from what I can make out the regulator doesn't come out through the glass opening... so why do they remove it? Yesterday I couldn't spell Engineer... Today I are one!
Post #418559 18th Dec 2016 10:44pm
Dolphinboy
Because of the shape of the rear door (with the rear wheel arch curve) the glass cannot be lowered enough to fully clear the 2 retaining bolts - It covers one of the retaining points of the regulator if left in. You have to remove the glass to be able to get your Allen key/Torx thingy in.
Post #418610 19th Dec 2016 10:30am
miggit
Evil or Very Mad Which bloody sadist designed that one then... it does make me wonder if they deliberately go out of their way to complicate things Evil or Very Mad
Rolling Eyes Still at least they used bolts.... the regulators on my Merc are riveted in Shocked Banging Head Banging Head Yesterday I couldn't spell Engineer... Today I are one!
Post #418715 19th Dec 2016 9:47pm
