Home > Maintenance & Mods (L322) > L322 slightly heavy power steering. Res is at top! |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Belt slipping? Ed |
18th Dec 2016 2:21pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Fluid is the right colour, some have had problems with the BECM causing heavy steering, basically it doesn't tell the system what speed you are doing so it defaults to minimal assistance which is what you get at motorway speeds.
18th Dec 2016 3:08pm |
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 |
Hi. I put bcu, meant bcm. Which it has had a new one fitted. Have just been looking at the garage paperwork. Doesn't say anything about replacing the servotronic valve transducer. I can't see where it says the rack was replaced either but I was told it had a used replacement fitted. |
18th Dec 2016 3:34pm |
Best to get it stuck on some diagnostics and see what that says... Pete
18th Dec 2016 3:48pm |
Yeh think I will book it in at DLS. The only other thing on it that's not right is the fuel guage, I filled it right up and it only went to 3/4 full. |
18th Dec 2016 4:00pm |
That's a known issue, costs a few hundred to fix, or live with it...
18th Dec 2016 4:09pm |
Hmm I will see if it fixes itself. It is an LPG car so maybe previous owner didn't use much petrol.
20th Dec 2016 2:25pm |
