Home > Technical (L322) > Turbo oil feed line blew TD6 2003
Palmz
Iceland 2003 Range Rover HSE Td6 Bonatti Grey
Hi all my turbo oil feed line blew, Luckily it blew while i was adjusting the car on the lift for a brake job. only lost a little bit of oil looks like the turbo survived.
do you guys recommend anything i should do while im in the im already planing on doing Valve lifters (tappets/adjusters) If you have any tips on that just they are appreciated.
I also wanted to ask where do you recommend to block of the EGR right at the Exhaust or somewhere else i noticed they use the exhaust to heat up the water temp faster.
Post #418543 18th Dec 2016 9:58pm
