Home > Maintenance & Mods (L322) > oil change without ramps/lift |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7905 |
You can do all of those oils yourself on your back with the car on the floor, just leave a door open and it won't drop, stick an axle stand under it if you like...
22nd Dec 2016 3:58pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Brilliant! Going to order the extra oils today and have a swat up tonight...grudge paying for a job I could do myself...cheers Pete |
22nd Dec 2016 4:06pm |
Do it like that every time, off road height and away you go .
22nd Dec 2016 7:56pm |
belldarr Member Since: 14 Jun 2014 Location: Bucks Posts: 149 |
I bought a vacuum pump last year - perfect for changing the oil in any car and most dealers use a version of this.
22nd Dec 2016 8:33pm |
As above and if you want more space park one sid on the edge of a curb for some extra clearance as above it's easy when standard, I now have to put the front up on ramps due to the sump guard and needing to get it down first FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
23rd Dec 2016 6:23pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 816 |
Just watch the engine sump plug, they strip at piece rate.
23rd Dec 2016 8:26pm |
I shall take a bit extra care then Picked up 10ltrs comma oil as per the wiki chart and a replacement sump plug/brass washer also got a large mechanics oil pan ..the oil for the diffs is enroute as well...gentlemen again thanks a lot for the pointers/advise... |
23rd Dec 2016 9:02pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
As it is only the gearbox access that requires something better that a squeezable I got the much smaller vacuum pump that transfers a litre at a time. It does do the axles and transfer box in one suck and blow which is a bonus. Sealey 1Ltr I think was £10 from the bay of e. |
24th Dec 2016 4:44pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Not ramps per se but I took a chainsaw to a 4x4" fence post, cut them into foot long sections with a 45 degree slope on one end. Nailed three together in parallel. Repeat 4 times.
24th Dec 2016 4:45pm |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
I find that ramps really help with things. The added height and workspace makes things much easier. Si. <This is my name.
24th Dec 2016 7:37pm |
