Home > Maintenance & Mods (L322) > Coolant Leak after getting it back from LPG conversion :( |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
I've spent £1800 in parts to give my rangie an overhaul, I was happy with the running of it, been on on the road 2 month and covered around 1000 miles so I was happy it was good to go for LPG conversion so booked it in. £2136 later I picked it up last night and got home, only a short journey and on turning off I get the dreaded coolant level low. Gets out to steam coming out the bonnet. Thought it must be down to Lpg conversion as I've fitted new rad, water pump inc new O Rings, low temp stat, oil cooler and pipes inc stat and new pipe from water pump to oil cooler.
22nd Dec 2016 6:40pm |
I fitted a brand new behr hella genuine water pump only 1000 miles ago. 2004 RR 4.4 V8 Autobiography |
22nd Dec 2016 7:25pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
LPG kits do cut into your water supply, this being a pain BMW heater system they have to be connected correctly other wise it can't flow the water correctly
22nd Dec 2016 8:51pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
A picture would be useful, to see where he's fitted the regulator. It should be below the header tank or it will never bleed. |
23rd Dec 2016 9:41pm |
Turned out to be the water pump gasket. It has slightly dislodged on fitting, just suprised it waited till now to let go. 2004 RR 4.4 V8 Autobiography |
24th Dec 2016 12:09am |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
A little off topic; I see you are in Warwickshire, same as me, who did you use for the lpg conversion? One of my other cars uses lpg and I have been looking for somewhere to get it serviced. |
24th Dec 2016 10:01am |
It was these http://www.lpg-cars.co.uk/ in coventry. 2004 RR 4.4 V8 Autobiography |
24th Dec 2016 7:21pm |
