Home > In Car Electronics (L322) > Hardwiring a Dashcam |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7747 |
I've done it twice
29th Dec 2016 8:20pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
I have done this on mine by using a piggy-back fuse into an existing fuse that is ignition live. This was behind the glove box. Then I used a 'female' cigarette socket that I had in the garage, so I did not have to chop the end off the wire that plugs into the dash cam.
29th Dec 2016 8:25pm |
Have a look at this
29th Dec 2016 8:26pm |
Dave Member Since: 03 May 2016 Location: Norfolk Posts: 187 |
This is how i did mine
29th Dec 2016 8:43pm |
What I did learn after I did mine is that the little AirBag badges on the pillars flip out and there is a single screw behind them to remove the entire pillar cover - at least that's the case on the L405 (I watched them replacing my windscreen)
29th Dec 2016 8:54pm |
RRR207 Member Since: 27 May 2016 Location: Basel Posts: 49 |
Great, thanks for such speedy help.
29th Dec 2016 8:56pm |
Yes - and you can decide whether to use a permanently live one or one that is switched with the ignition
29th Dec 2016 9:02pm |
The problem is if you used a switch fuse then itncuts out when parked up.
30th Dec 2016 4:53pm |
Yep, as alistair says, just 1 torx screw to hold the a pillar trim on. Takes a little lining up with the tangs to get it back together but it's a matter of patience. There is nothing that can't be fixed with a hammer😜😜
30th Dec 2016 5:09pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Along with my Blackvue I also purchased a gizmo that shuts down the dashcam should the battery voltage drop below a certain value. Have left my fatty for up to nearly 4 weeks with no starting issues. Previous cars:
31st Dec 2016 10:51am |
Going for the ignition-live option, car doesn't get used for days on end so battery/starting could become an issue with a constant-live situation.
1st Jan 2017 10:31pm |
Did the same with mine, you can adjust the voltage parameters so when it drop below it shut down the dash cam its called a Power Magic pro, you can see it in my install post above https://www.blackvue.com/power-magic-pro/ Dave 2012 Vogue Westminster 4.4 |
2nd Jan 2017 4:33pm |
Hi Dave,
2nd Jan 2017 4:49pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
It would work for anything plugged in to it. 2006 4.2 SC
2nd Jan 2017 4:50pm |
