Home > Technical (L322) > Is it possible to open bonnet without using lever inside?? |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 |
cant you unlock via key ? |
2nd Jan 2017 11:29am |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
Agree that the first thing to try is to open the drivers door with the key. That should work unless the door card has been taken off and the physical lock link hasn't been put back on properly.
2nd Jan 2017 11:44am |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
2nd Jan 2017 11:52am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3194 |
His problem is he is unable to open the car to access the bonnet pull lever. John
2nd Jan 2017 12:08pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
From what I can see the only way into a car with a flat battery is through the drives door using the key... if for some reason the key doesn't work your going to be in a world of pain, cos somethings going to get broken... not sure if you can release the bonnet from behind the grill (which would be a cheaper option than a window) Yesterday I couldn't spell Engineer... Today I are one!
2nd Jan 2017 12:44pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
Would sacrificing the grille allow access to the mechanical mechanism? 405 AB exec seats Baltic and Cirrus
2nd Jan 2017 12:47pm |
Skip720 Member Since: 12 Jun 2016 Location: Wakefield Posts: 32 |
Thank you all for your advice. I called AA and he air bagged door and popped bonnet that way. The key doesn't work in the lock is this another problem and can it be fixed, and if so how. Lol
2nd Jan 2017 4:20pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Door card off and you will probably see where it's disconnected. Do it asap so you're not stuck again.
2nd Jan 2017 4:34pm |
I too thought that it was a door-card off job, but apparently not. It appears you can sort it out by taking the exterior handle off and then refitting carefully, making sure that the short rod connecting the key barrel to the lock mech is at 90 degrees to the door and so working properly. Not sure if that's any easier than taking the door card off, to be honest.
2nd Jan 2017 4:50pm |
chris595959 Member Since: 09 Jan 2012 Location: Brighton Posts: 61 |
Anyway of getting a positive connection onto the starter from underneath the vehicle to back feed and open door |
2nd Jan 2017 4:59pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Pretty sure the manual driver's door lock should work without any charge in the battery. Whilst I was working on the EGR valves I had the battery disconnected for days on end but was using the keys to lock and unlock the vehicle. Admittedly I had unlocked it using the remote and the locked it with the key so perhaps didn't engage all the locks. Ed |
2nd Jan 2017 9:35pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Yes, it should. Mine didn't. I removed the lock as per manual (one screw in the door shut area) and found the piece that connects the lock to the mechanism had drooped a bit when being fitted so it didn't engage. Simply refitting it worked. BMWs are known to break these pieces, repair parts are available on eBay. |
3rd Jan 2017 11:21am |
