Home > Technical (L322) > Suspension recalibration! |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
I had a LR technician look at my car last night, kept throwing an air suspension error, I changed a height sensor and it hasn't come back, but he said my calibration was too high, and thinks that it was so high every time I go around a corner a sensor was going out of range, causing an articulation error! Does this look about right at different heights? Looks better to me than it was!
6th Jan 2017 11:41am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
you can check the heights yourself using this chart,
6th Jan 2017 11:51am |
There isn't a height for the stupid 22inch wheels that are on the car, I think we did it to 20. The guy said there wasn't much in it really!
6th Jan 2017 12:01pm |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
I'm convinced mine is sitting too high.
6th Jan 2017 5:23pm |
Post a picture and we can help you out!
6th Jan 2017 5:44pm |
Those measurements Stan put up are taken from the centre of the hub so regardless of size of wheel they will work . 2008 MY Supercharged
7th Jan 2017 2:35am |
Yes, I put the chart together for different rims because IIRC the All Comms was taking measurements from the rim not the hub centre, if not i know there was a reason for it!
7th Jan 2017 10:35am |
the rear is supposed to be 1cm lower than the front..
7th Jan 2017 12:31pm |
Tim - mine was about 50mm too high all around!
7th Jan 2017 1:15pm |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Just played with mine, initially FR = 500 FL = 520 RR = 470 RR = 490 so all over the place
7th Jan 2017 3:48pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Was that the measurements on the iid app or from taking them manually?? If from the iid app they will be all different ? |
7th Jan 2017 4:41pm |
@ kbald
7th Jan 2017 7:00pm |
Hi joe90 that's what I meant if he simply changed the settings using the iid tool it won't be right so he would need to e measure correctly as per the chart you produced. On the Bluetooth iid it gives you figures for the suspension on the app. |
7th Jan 2017 7:40pm |
yep, copious amount of measuring, then calibrated left to right but as the original measurements (measured from middle wheel to wheel arch) were so far out manually adjusted heights to get the car roughly square then recalibrated.
7th Jan 2017 9:02pm |
