Home > Technical (L322) > chain guide renewal - 2004 BMW 4.4L V8 Petrol - Update |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2023 |
loving those wooden camshaft setting tools! |
18th Jan 2017 8:35pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3050 |
Lovely stuff guys. Many thanks. My vanos were fine prior to this. No real tapping except for the injectors and the lpg injectors. So that's a no to new vanos and a saving of £1k!
19th Jan 2017 12:41am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7905 |
This is quoted by LPG neighsayers... it is correct though, LPG burns around 10 degrees hotter than petrol, but seeing as they both burn at around a 1000 degrees it doesn't make a lot of difference....!!! The advantage of LPG is that the oil barely gets dirty between changes as there are far less combustion particles getting into it, this keeps oilways from blocking, LPG also keeps the inlet tract and valves much cleaner. Good luck with the fix Flipper , personally I wouldn't do the Vanos and I think the price is not unreasonable but certainly not cheap..... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
19th Jan 2017 1:15am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I admit i don't have any evidence it is just my thoughts as all the cars i have seen with failed guides in the lower mileage bracket of 100K - 140K for example have had LPG and mine has never had LPG and my guides looked great at 120K.
19th Jan 2017 8:30am |
They say they only fit LR gen parts as they come with a 2 year/20,000 mile warranty. I could stipulate my own choice but tbh just want to get it done and finished now.
19th Jan 2017 11:31am |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
Would recommend http://www.lrsengineering.co.uk/
19th Jan 2017 12:05pm |
Wouldn't hurt as you are already in deep and you can see mine had started to get a bit crusty Should be about £70 for genuine LR http://www.brit-car.co.uk/product.php/5032...over_vogue if they already have the front cover off then they have done the hard work, putting it back together is a pleasure, timing it was a bit tricky with mine but the cheap locking blocks were a bit 'relaxed' and as it was my first time I set it and checked it and reset and checked and then reset again just to make sure |
19th Jan 2017 8:40pm |
Hhmmmm, very confused now...
20th Jan 2017 12:34am |
ipwn Member Since: 08 Aug 2015 Location: Yorkshire Posts: 48 |
You can just rebuild the vanos units with new seals? Company in Sheffield do them. |
20th Jan 2017 12:50am |
The valley pan is supplied with sealer already supplied, the other gasket or seal is probably the inlet manifold rubber seals as this sits above valley pan.
20th Jan 2017 1:39am |
Originally your car would have a valley pan, with a rubber gasket. This is unavailable now, you now get a new cover with an applied and hard, bead of sealant. Bolts straight on.
20th Jan 2017 9:49am |
Thanks again Andy and John boy. Will do. |
20th Jan 2017 11:23am |
Well got the old girl back today. She is running sweet and sounding great again. The mechs seemed to know their stuff and didnt cut corners. All necessary gaskets changed. They said she was in great nick otherwise.
25th Jan 2017 4:12pm |
Glad it's all working again 2003 Range Rover 4.4 Litre V8 - Adriatic blue
25th Jan 2017 5:49pm |
