Home > Maintenance & Mods (L322) > Headlight wiper motor rebuild
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Has anyone tried to repair the headlight wiper motor? I found a breakdown of a similar Volvo motor and in their case the grease gets thick or even solidifies.
Post #421663 7th Jan 2017 8:24pm
holidaychicken
I had a look in mine and remember finding they couldn't be repaired due to a gear being damaged , I bought a new pair for a mere 300 but you can pick them up for 30 on eBay
Post #421699 8th Jan 2017 2:58am
doclees
Thanks. I'm even finding them new here as low as $200. It's not necessary to have them working in the US but I like to try to keep it all working. Most of what I will find used will have about the same wear and tear as any dead or dying one so if it can't fixed might as well go new.
Post #421793 8th Jan 2017 6:50pm
holidaychicken
I am not sure if i kept my dead ones, i probably did as I am a bit of a hoarder, i will try and take a pic of my old one taken apart. i think the problem is they have water running through the centre of them to feed the wiper and they freeze up and the wiper sticks to the glass and get damaged when trying to use them.
Either that or it is just wear and tear
Post #421822 8th Jan 2017 9:29pm
doclees
That would be great to see the guts
Post #421845 9th Jan 2017 2:45am
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I have one where the contacts burnt out, If anyone wants it it is available....
Post #421921 9th Jan 2017 4:14pm
holidaychicken
There is quite a lot going on in there
i have seen more teeth on the Jeremy Kyle Show !
Post #421993 9th Jan 2017 9:14pm
doclees
Yes lots going on. Looks like in your case the gear on the output shaft was the problem. Would a spot weld and reshape worked on that metal?
Post #422018 10th Jan 2017 2:38am
holidaychicken
That is a good call, i have a mig welder that I could use to deposit a blob of weld on the gear and then reshape.
I think somebody has already had one side apart, may have been me, and lost the rack that turns the wiper
Post #422025 10th Jan 2017 7:53am
holidaychicken
The other option is to remove the wipers, blank off the wiper arm holes and fit the high pressure washer and jets from the later model , will take a bit of fiddling to get the washers to fit into the bumper though
Post #422149 10th Jan 2017 10:59pm
doclees
Hmmmm.... are there 2 pumps or one? They look like they mount horizontal compared to vertical on the washer tank. Beter check to see if RAVE covers this year.
Post #422158 11th Jan 2017 4:36am
mr_spock
On my 2003 there are 3 pumps on the washer reservoir - rear screen, front screen and headlamps.
Post #422197 11th Jan 2017 1:53pm
doclees
I was referencing the 2006 MY that did away with the wipers and just has jets.
Post #422323 12th Jan 2017 2:51am
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
