Home > Technical (L322) > Remote Fbh aerial
dolph34
Remote Fbh aerial
Hi all , looking for some pointers on where the aerial for the fbh remote is attached to the window please 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #422210 11th Jan 2017 4:41pm
From memory they use the TV aerial via the signal amplifier right hand side . 2008 MY Supercharged
Post #422320 12th Jan 2017 1:44am
dolph34
Thabk you but i bought the unit secondhand ( receiver ) and there a cable from the loom that plugs in but no spare aerial connection. I bought a new one on line so just looking for advice on where it attaches. It has a sicky side so i will only get one shot at it 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #422446 12th Jan 2017 7:37pm
mike whiskey
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
The genuine solution involves using the TV antenna in the glass, and a splitter that provides a seperate connection.
If you are retrofitting the heater remote then you wont have that connection. Your aftermarket antenna doesn't have a 'correct' location, so its a case of finding somewhere unobtrusive to nmount it and where you can run the wiring behind panels to keep it hidden.
Mine is right at the top of that window, with the cable under the rear quarter panel. I found a tiny gap behind the 'shelf' that the cable can be wriggled through.
MW Car history includes: LR Series 3, RR Classic x 4, LR 101, Discovery 1 and 2 and now FFRR.
Yes I'm a masochist....
Post #422519 13th Jan 2017 9:19am
dolph34
Thanks very much, much appreciated 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #422556 13th Jan 2017 12:35pm
