Home > Technical (L322) > Flickering Rear Lights |
You need to fill in your car profile or else we have to guess what car you have , have you or anyone else fitted LED bulbs ? 2008 MY Supercharged
12th Jan 2017 1:48am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
If you have LED number plate lights then they may be trying to catch fire like mine tried to and also confuse the crap out of your LCM if not toast it |
12th Jan 2017 3:12am |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Good point on the profile, forgot to update when I bought the FFRR (it's a 2006 TD6 BTW)
12th Jan 2017 9:42am |
LED's have to be canbus error free and /or with a resistor ( not sure if it's both or one or other , never fitted to mine) and the cold monitoring can be turned off with an iiD Tool . if you are getting deliberate set flashes each time you start up it is just cold monitoring . When I had LED main beams I just let it because it never bothered me . 2008 MY Supercharged
12th Jan 2017 11:24am |
The LCM causes the lights to flash but in my case i was getting all sorts of dashboard lighting errors but none relating to the rear number plate light but i decided to check mine and they had started to burn.
12th Jan 2017 8:17pm |
Thanks for the input, I am not getting any errors at all on IID but will pop the number plate lights out and inspect/swap and report back
13th Jan 2017 10:17am |
it is worth a look, all my errors were on the dashboard display but mine is an old 04 |
13th Jan 2017 6:36pm |
