Home > Technical (L322) > Air suspension in active |
D34NO Member Since: 21 Jul 2016 Location: Lincoln Posts: 46 |
Hi all, i drove home this evening and this message popped up 'Air suspension inactive' also i noticed the light on the dial in the cab is unlit, upon reaching home i got out and saw that the front has dropped but the rear is up, so my wagon looks like a cross between a dragster and a monster truck!! there is also a ticking and high pitched sort of whistling/tapping noise from under the engine which someone said could be alternator related, i have also washed my car earlier with a Karcher. just mentioning all these things due to reading a few threads and there seems to be some similarities. ive tried the lock to lock but nothing, hence im writing this. the Gap iiD tool seems to be a popular choice in figuring this out but i need to know first ifits gonna just be a case of spending a few pennies on parts to fix it or the diagnostic will sort it out first.
13th Jan 2017 6:28pm |
yeah im beginning to think this iiD tool is a good option, so if ive read correctly a hard fault can be rectified by disconnecting the battery for a long time say over night? |
13th Jan 2017 6:40pm |
13th Jan 2017 6:50pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
It never worked for me but my compressor had lost the will exhale. for what it's worth when mine went into hard fault it did the dragster thing that yours has and I was convinced it was as a height sensor, valve or a bag at fault..only for way to find out is through diagnostic..it's a good investment if your keeping the fatty |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3192 |
I'm a little confused. You do appear to have a hard fault which requires clearing with the iiD tool or the like.
13th Jan 2017 6:52pm |
there is no light on the actual control knob and also there is no light on the light panel next to it which usually indicate what height the vehicle is at. |
13th Jan 2017 7:03pm |
Thanks that is clearer now.
13th Jan 2017 7:05pm |
guess i best starting looking around to find one of these tools then |
13th Jan 2017 7:45pm |
Pm duckworths mate for a price.. recommend the Bluetooth version.. |
13th Jan 2017 9:04pm |
Ordered iiD tool this morning hopefully this will help out |
14th Jan 2017 3:58pm |
OK so my iiD tool turned up this morning,(thank you Duckworths) got it all set up and initial scan had 51 faults! however i cleared them and eventually it dropped to two (however i'm still not convinced those are the only ones) the Air suspension message cleared for a while...... then came back.....retried and it cleared, i managed to try and use the control in the cab to adjust it to see if it would work however the left front wing came up, the rear left wing is now somewhere in the clouds and the front right is rock bottom. the Air susp message comes back every now and then along with max offroad speed 30 mph, I' guessing that's due to the arse end being up so high.
17th Jan 2017 11:17am |
