Home > Technical (L322) > Windshield wiper relay |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
It's behind the battery, behind a plastic cover. A bit fiddly to get to, but not too bad.
14th Jan 2017 9:27pm |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 378 |
Hi Steve,
14th Jan 2017 11:58pm |
OK, well the wiper relay certainly plays a role in sending a trigger that they have reached the parked position, however I cant see that simply pulling the relay and putting it back in again will make any difference. As you needed to remove the battery to get to the relay, it won't be driveable as it is.
15th Jan 2017 10:39am |
Thanks Steve!
15th Jan 2017 4:15pm |
Hi Steve,
17th Jan 2017 1:38am |
Number 9 in this diagram. For reference, number 8 is the headlamp washer relay.
17th Jan 2017 8:56am |
Thanks Steve,
17th Jan 2017 4:24pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34908 |
theres a black fuse box in the engine compartment , the relay should be in there.... |
17th Jan 2017 4:32pm |
Thanks Stan, thats what i'm trying to find, where the windshield wiper relay is. Mike |
17th Jan 2017 4:36pm |
is there not a diagram on the underside of the lid ?... |
17th Jan 2017 5:03pm |
does this help,
17th Jan 2017 5:09pm |
No diagram but I just pulled the cover off the big plastic box with the 10 torx nuts in front of the battery and found this. One of these has to be the windshield wiper relay wouldn't you think?
17th Jan 2017 5:16pm |
Mike,
17th Jan 2017 5:21pm |
Thanks Stan! So is the 1 relay for the wipers and intermittent wipers?? |
17th Jan 2017 5:26pm |
