Home > Maintenance & Mods (L322) > Rear tail light bulb failure message |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34871 |
has the error message now gone since you have cleaned the contacts.. |
16th Jan 2017 11:36am |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 |
Mines the same. It always bongs and says "check brake light" when starting or turning off. It did it before and after I updated the tail lights, so it's presumably, like yours, a fault in the continuity PWM circuit NW060
16th Jan 2017 11:44am |
RR-EVO Member Since: 28 Mar 2016 Location: paris Posts: 17 |
No... I suspect either a problem with the wiring of the vehicle or with the ECU |
16th Jan 2017 11:56am |
any replacement led bulbs fitted per chance? |
16th Jan 2017 12:00pm |
No vehicle is stock. No message during 6 months of ownership.
16th Jan 2017 12:10pm |
strange...it might be an intermittent bulb failure or as you have suggested, a fault in the wiring .. |
16th Jan 2017 12:13pm |
