![]() | Home > Technical (L322) > Approach Lamp Control, Door mirrors. |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
Hi,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35758 ![]() ![]() |
its a fault Bob..
Many thanks Stan,
if you look underneath one end has a indentation.. |
So, the problem has morphed, light night I observed that the Drivers Side puddle light was on permanently, I.e. Not just when the door was being unlocked.
So the situation is:
you've probably tried this but what about doing a battery disconnect... ... - .- -.
Yes, yesterday, I had also tried disconnecting the PCM ECU for a separate issue and so had disconnected DD the battery -ve for 10mins. |
Still not solved this problem.
Well, 2 years later and I still have this problem. Anybody else experienced this ? -------------------------------------
Ok, I’ve purchased a replacement Drivers Door. O duke off eBay. Does anybody have access to Topix or a workshop manual to share how to change the Drivers Door Module ?
I have searched through the Workshop Manual, but still cant find the location of the Drivers Door Module.
Many thanks Richard -------------------------------------
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
You're welcome.
