Home > Technical (L322) > folding door mirrors |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
the Westie has an issue with the drivers dorr mirror.
17th Jan 2017 8:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
makes me think the battery is lacking power.....does this kinda happen when you first open up or when the FF has been run and warmed up a bit as well.. |
17th Jan 2017 9:04pm |
battery was fully charged just 2 days ago but might check to see what the C-Tek charger says in the morning. Another story that I am waiting for the selling dealer to get back to me on.
17th Jan 2017 9:07pm |
so the door switch is sending power to the mirror directly without problems , whereas the remote sends a signal to an ecu and that then sends the power to close/open which isnt working correctly...ecu? |
17th Jan 2017 9:19pm |
thanks. an email to selling dealer to explain issue and see what they are going to do. Regards
17th Jan 2017 9:22pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Any update on this? I have exactly the same symptoms Bish.
1st Feb 2017 8:53pm |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Have you popped the cover off to have a look at the small metal arm on the micro switch? Could be thats it not fitted properly and the mirror isn't sure what position it is in.
1st Feb 2017 11:02pm |
Well it seems a good soak in WD40 and a few cycles of the mirrors and normal service seems to have been restored...... for now...... Bish.
7th Feb 2017 11:24pm |
