Home > Maintenance & Mods (L322) > Best way to change coolant
Madmutt0
Hi everyone I want to renew my coolant is there a easy way to drain down the system it's a BMW v8 l322
Thanks for any info
Post #424037 20th Jan 2017 10:25pm
Drain off from the radiator and the cylinder block.
Do a flush through if you want using plain water into the expansion tank with drain valves open, or however you wish.
Refill with same type of coolant through expansion tank.
Bleed the system as prescribed / required using the bleed valves on the expansion tank and coolant pipes.
Check the wiki for download links for RAVE .
Post #424046 20th Jan 2017 11:26pm
